Thanks for the help on 3600gas
kenbob
I have been helping my friend with his 3600 gas and you have been helping me. The lockout switch in the transmission was the reason for it not turning over, just as you folks said. He does have either a leaking rear main or a bad pan gasket. This gas tractor has about 1400 hrs. Which leak is the most common on this tractor? Is it worth just trying to replace the pan gasket? THanks again.
also the tractor was not started in over 2 years. Will these seals/gaskets fatten up with some use?
