745 Loader 19-863 valve springs?
I have a 1980 340 with a 19-863 loader. The hydraulic valve has two springs, both of which need to be replaced. One is 7701003 which is 28.00 at Messicks. The other is 7701786 which is 110.00. Has anyone ever found an alternative spring for the 7701786? 110.00 for a spring is crazy.
Here is a link to the valve diagram: https://www.messicks.com/nh/66441
Click on Control Valve in the left column. Item numbers 15 & 22
Take some good pictures of the valve and visit your local hydraulic shop with the springs you need. Any
reputable shop should be able to help you.
