I'D Numbers
geraint
New User
I have a 1957 Ford 600 it has several numbers on the engine and trans and axle.I hope some one can give me some idea what they are?
Engine left side as you sit in seat the flat spot over starter <>ll852<>
Engine left side bottom above oil pan 4BR1
Transmission left side NG4124
Axle left side 4175
Engine R/T Bottom above oil pan. DIF5
EAE-6015-F
The tractor is a 5-speed 134 cu.
Hey if anybody can help me I'd appreciate it.
(quoted from post at 17:13:59 10/15/19) I have a 1957 Ford 600 it has several numbers on the engine and trans and axle.I hope some one can give me some idea what they are?
Engine left side as you sit in seat the flat spot over starter &lt;&gt;ll852&lt;&gt;
Axle left side 4175
EAE-6015-F
11852 should be the serial number which is for a 1955 year model, 57 model would have 6 numbers, check to make sure you haven't missed one.
Only other number I can help with is EAE-6015-F which is the casting number for a 134 engine built between 1953 and 1957
The fact that it has a 5 spd trans makes it a 650 model if it has a standard pto or 660 model if it has live pto with two stage clutch.
The model number is stamped in the same location as the serial number but father back toward the battery box and possibly under the air cleaner bowl.
