Backhoe Attachment
I am wanting to add a backhoe attachment to my 3600 since it don't have a PTO. It does have rear hydraulic hoses for equipment hook up. I installed a 735 loader already. Will it have enough hydraulic pressure to work this set up on back. Thanks
3600's tractor hydraulics alone is not a good match for a 3 pt mounted backhoe. You would need a self contained unit with it's own reservoir and PTO driven pump and I would highly recommend a 4 Pt full frame backhoe mount. While handy and can do some work, can also be very hard on the tractor without the dedicated backhoe mount. I found newer photos of one of these mount for thousand series ford tractors, no time to post them now, maybe later today.
The Backhoe attachment works on 4.5 to 5 gpm and the 3600 shows it has 8.5 gpm. I plan on building a sub frame bracket to mount it later if I do buy it
My hoe, which attaches through a subframe, is borderline slow and my tractor pumps 10.3 GPM. I don't think that you will be happy.
