Sounds like someone installed the wrong key switch in the past, or else you don't have the thermostart, which was an option. The correct key switch should have 2 spring loaded positions. One for thermostart, and one for crank.
Look for the thermostart plug in the front of the intake manifold. You should see a fuel line and 10 gauge wire attached to it.
