Company Logo Shop Now
TractorLinks.com
Order Ford 861 Parts Online
Re: 1957 861 Carb tuning issue
showcrop
10-15-2019 15:20:28
Set the main jet, "power jet" as you call it, at 2.5 turns out and forget it unless you are going to enter a pulling competition. Set the throttle at 500 RPMs and adjust the low speed for highest RPMs. If you were recently trying to start it with the choke closed and it didn't start in 5 seconds you should have gas sitting in the inlet.
polymerjohn
10-18-2019 09:20:22
 Re: 1957 861 Carb tuning issue in reply to showcrop, 10-15-2019 15:20:28
Question: Does it make sense to tune the engine, at least the idle setting, without the linkage connected. Then make the adjustment to the linkage that connect it to the carb linkage ball. If I connect my linkage now the way it is set, the linkage will hold the throttle plate off the stop, not good. Logic tells me to adjust the carb to run properly, then adjust the linkage to properly connect to the carburetor "ball".
What does the linkage in front of the carburetor do? It has some association with the alternator. Is it a governor of some type?
Polymerjohn in OK
Copyright © 1997-2020 Yesterday's Tractor Co.
