changing 730 loader valve spool seals
riveroadrat
Is there any thing that would give me a problem changing the spool seals. This valve has float on the lift arm spool. I read a previous post about not putting the seals in first but putting the spool in and push it past the oring seat. I didn't quite understand that method, it was so you wouldn't cut the seals by putting the sharp edges of the spool in after you installed the seals.
pics
