Company Logo Shop Now
TractorLinks.com
Re: TW35 Water In Oil
Bern
10-15-2019 10:27:52
I'd be shocked if you can't re-use the pistons. Check the oil pump carefully while you have it apart, specifically the bore that the relief valve slides in. BIG problem area on those engines.
FOMOCO Farmer
10-15-2019 18:45:58
 Re: TW35 Water In Oil in reply to Bern, 10-15-2019 10:27:52
I'm probably going to put a new oil pump in it. My dad would turn over in his grave if he knew I didn't install a new oil pump. He may if he finds out I reuse the pistons!!
Bern
10-15-2019 21:15:43
 Re: TW35 Water In Oil in reply to FOMOCO Farmer, 10-15-2019 18:45:58
Suggest ordering the smaller pump for the TW5 engine. I did that once on a 35, and it still pegged a 100 PSI gauge with cold oil. Those oil pumps are way too big for the application, especially on a 35 that do not have a bypass oil cooler.
Unless it's been seriously overheated in its past, the pistons will go forever in those engines.
Copyright © 1997-2020 Yesterday's Tractor Co.
