Company Logo Shop Now
TractorLinks.com
Re: TW35 Water In Oil
FOMOCO Farmer
10-15-2019 06:15:55
Thanks Bern!! I hope to reuse the pistons as the engine doesn't have a lot of hours on it. Somewhere around 5500 hrs. I'll have the head worked. It has good oil pressure. The injection pump has about 50 hours on it. Injectors will be checked. Clutch is new. It'll be a while before I tear it down. Gotta get the crop harvested. I parked the tractor for fear of ruining the motor. Thanks again.
Bern
10-15-2019 10:27:52
 Re: TW35 Water In Oil in reply to FOMOCO Farmer, 10-15-2019 06:15:55
I'd be shocked if you can't re-use the pistons. Check the oil pump carefully while you have it apart, specifically the bore that the relief valve slides in. BIG problem area on those engines.
FOMOCO Farmer
10-15-2019 18:45:58
 Re: TW35 Water In Oil in reply to Bern, 10-15-2019 10:27:52
I'm probably going to put a new oil pump in it. My dad would turn over in his grave if he knew I didn't install a new oil pump. He may if he finds out I reuse the pistons!!
Bern
10-15-2019 21:15:43
 Re: TW35 Water In Oil in reply to FOMOCO Farmer, 10-15-2019 18:45:58
Suggest ordering the smaller pump for the TW5 engine. I did that once on a 35, and it still pegged a 100 PSI gauge with cold oil. Those oil pumps are way too big for the application, especially on a 35 that do not have a bypass oil cooler.
Unless it's been seriously overheated in its past, the pistons will go forever in those engines.
Copyright © 1997-2020 Yesterday's Tractor Co.
