I was attempting to cut hay with my Ford 800, and made it only once around a small field.
The tractor started sputtering, and was losing power, so I stopped. I dismounted from the left side and noticed that the exhaust system was much hotter than usual. I'd been monitoring the temperature gauge while I was cutting, and it vacillated between the center and just right of the center in the green (but always stayed comfortably within the green zone).
The valve cover was too hot to touch.
The radiator seemed hot, but not as hot as the valve cover.
The muffler was discolored (I assume from heat).
I checked the coolant level before I began, and then again after it cooled down, and it was still full.
So far I've checked the timing, points, cap, rotor, plugs wires, and plugs. I rebuilt the carburetor (I had the kit and was intending to do that before I started cutting). I also checked compression, and all cylinders were good and within 5 pounds of each other.
Everything looked good except the point gap was slightly off, and the coil was slightly out of spec on the secondary winding resistance. I set the points and swapped out the coil with a coil that was withing specifications.
The outside of the carburetor was dirty, but the inside was surprisingly clean.
Nothing I've done has changed anything. It runs fine at idle. Anything over idle and it gives a sputter or two every 10 seconds or so, and the exhaust gets abnormally hot. This is with it parked, and under no load.
My latest thought is that perhaps my temperature gauge is faulty, and I have a non-functioning, or barely functioning thermostat. I'm not sure how that would cause sputtering, but I'm running out of ideas.
I'd appreciate any thoughts on this.
