Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
Ford 600 oil pressure line ...
tdwinklr@gmail.com
10-14-2019 11:37:40
I'm replacing the damaged oil pressure gauge copper line on a Ford 600. The new gauge/line I bought from YT here but instead of the line having male fittings to go straight into the block, this line has female fittings and the adapters they sent with the gauge are not going to work.
Now I'm having a lot of trouble just finding a fitting that will let me convert the female fitting to a male.
Any ideas?
tdwinklr@gmail.com
10-15-2019 05:40:34
 Re: Ford 600 oil pressure line ... in reply to tdwinklr@gmail.com, 10-14-2019 11:37:40
Looks like I'll have to because I can't find this size fitting anywhere around here. Thx.
Hobo,NC
10-15-2019 05:00:20
I don't have a 1/8" flare tool : ( so I used an oil line kit from napa # 701-2154. I did not remove the line at the pump so spliced into it yes I cheated...
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=620406
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=674522
If you use this kit make sure you install the sleeves all the way on the line so they protrude a tad so once its crushed it is not going anywhere...
Bob
10-14-2019 21:35:50
Also, I meant to add, it sounds like you still have the damaged line, you could remove the old fittings and install on the new line, then flare.
tdwinklr@gmail.com
10-14-2019 12:18:47
thank you sir!
Bob
10-14-2019 12:08:21
You need a 1/8" "inverted flare nut".
Used to be common, now not so much.
Any auto parts store that sells Tomkins/Edelman products should be able to get you one.
Also available through Amazon, but NOT cheap!
https://www.amazon.com/Tomkins-121002-Edelmann-Fitting/dp/B0012ON8WU
Copyright © 1997-2020 Yesterday's Tractor Co.
