Company Logo Shop Now
Order Ford 3000 Parts Online
Ford 3000 (gas 3 cyl, 1966) not humming
taylor74
10-14-2019 10:24:25
This good tractor started missing out. Instead of the consistent, steady hum from the engine it Hums for a split second, falters, immediately recovers, Hums, falters, etc. (HUM, cough-cough, HUM). It does this under a load and while idling. It does not seem to lose any power. It just HUMS, coughs and HUMS.
I checked the plugs with an inline spark tester. All 3 cylinders are sparking. Installed a new fuel pump a couple of months ago and it was running very well. Fuel flow seems to be ok.
Carb should be free of carbon as I always use a fuel additive.
Any thoughts on the most logical problem area (carb, distributor, etc)?? Thanks for any advice!!
Lynn Patrick
10-15-2019 06:04:24
 Re: Ford 3000 (gas 3 cyl, 1966) not humming in reply to taylor74, 10-14-2019 10:24:25
Again I ask, what points & plugs are you using? Some brands today don't last as long as we would think.
taylor74
10-16-2019 19:56:00
 Re: Ford 3000 (gas 3 cyl, 1966) not humming in reply to Lynn Patrick, 10-15-2019 06:04:24
Hi,
I checked the plugs: Autolite 405. I can't tell about brand the points or condenser.
Lynn Patrick
10-14-2019 18:00:59
What points and spark plugs are you using & how old are they?
taylor74
10-15-2019 00:17:26
 Re: Ford 3000 (gas 3 cyl, 1966) not humming in reply to Lynn Patrick, 10-14-2019 18:00:59
The plugs, points and condenser were installed about 4 years ago by a mechanic. The tractor has run well up until now.
gears
10-14-2019 16:21:42
Does choking it change anything?
taylor74
10-15-2019 00:19:42
 Re: Ford 3000 (gas 3 cyl, 1966) not humming in reply to gears, 10-14-2019 16:21:42
Choking is needed to start the tractor but once it warms up no choke is needed. When it misses out choking briefly helps.
Copyright © 1997-2020 Yesterday's Tractor Co.
