Company Logo Shop Now
TractorLinks.com
Order Ford 2600 Parts Online
Ford 2600 steering issues
Wrestler22
10-13-2019 21:43:26
Hello all,
Looking to get some help with the steering problems of my 1980 2600.
When I bought the tractor around a year ago, it had this steering issue and now I am looking to fix it. The steering wheel is very loose (lots of play) and it almost feels like the steering is delayed. When I turn the steering wheel and stop it, the tires keep moving for an additional 2-3 seconds. This obviously makes the tractor go all over.
I just replaced the link arm ball joint and it did nothing. Steering linkage is tight.
Any help would be appreciated. Thanks!
CTPhil
10-14-2019 15:37:42
 Re: Ford 2600 steering issues in reply to Wrestler22, 10-13-2019 21:43:26
The worst part of the job is getting the dash cowl off. Not hard, just time consuming. You don't have to take the column all the way down to get to that washer, just the top part off. If you see the washer is in pieces I'd go no further, just new seals in the part you took off, new washer, adjust the nut down and stake it and reassemble. if you're lucky the top of the steering shaft just under the steering wheel won't be rough from rust.
Wrestler22
10-14-2019 11:18:41
Yes it does have power steering. I am assuming the problem is in the steering box like you all have said. The tractor does turn easy even with heavy loads in the loader.
With that being said, how difficult is diving into the steering box? Sounds like a real headache
CTPhil
10-14-2019 10:57:23
That would be my first thought too. Symptoms fit.
Bern
10-14-2019 08:45:00
Is it manual steering? If so, see if the steering wheel moves up and down as you turn it. If it does, the upper bearing in the column is toast.
Ultradog MN
10-14-2019 06:40:19
Is this power steering?
If so, someone has likely been in there and did not properly tighten - or stake the upper nut according to the manual.
Part # 21 at the link below.
SkipperII
10-14-2019 09:25:35
 Re: Ford 2600 steering issues in reply to Ultradog MN, 10-14-2019 06:40:19
It is also possible the spring washer, part #20 in the diagram, is broken.
Wrestler22
10-14-2019 11:19:17
 Re: Ford 2600 steering issues in reply to SkipperII, 10-14-2019 09:25:35
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
