Company Logo Shop Now
TractorLinks.com
Order Ford 2000 Parts Online
1970 Ford 2000 Not Charging
hbryant123
10-13-2019 19:59:49
I have determined my tractor is not charging, im getting 11.9 volts on the battery no matter what rpm. I need help in testing the generator, i seen it has a large and a small spade on it. If possible ide like to test the generator, i figure it has to be either the generator or voltage regulator ! wiring seems to be in place no cut wires. thanks in advance ! im excited to learn more about my tractor !
hbryant123
10-14-2019 10:32:06
 Re: 1970 Ford 2000 Not Charging in reply to hbryant123, 10-13-2019 19:59:49
I will give it a try after work!
Bern
10-13-2019 21:17:48
Put voltmeter on battery. Remove small "F" wire on generator. Take jumper wire and run from battery hot to small F terminal on generator. You should see a small spark when you make the connection. If so, start the engine and rev it up. Voltage should start to rise on meter. If it does, generator is fine and the voltage regulator is the most likely problem.
hbryant123
10-14-2019 15:08:03
 Re: 1970 Ford 2000 Not Charging in reply to Bern, 10-13-2019 21:17:48
I tried polarizing the generator no luck battery is still not charging. I tried checking output on the generator only got 2.9 volts seems like the generator is bad but idk.
Bern
10-14-2019 18:38:08
 Re: 1970 Ford 2000 Not Charging in reply to hbryant123, 10-14-2019 15:08:03
Did you leave the jumper hooked up while you checked the voltage? If so, suspect dirty/worn brushes. Easy enough to fix.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
