Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
Re: I'm selling my Ford 4000 SU and need price advice...
Beark34
10-13-2019 07:47:54
what do you mean? The front axels aren't sufficient?
Billy NY
10-13-2019 14:17:01
 Re: I'm selling my Ford 4000 SU and need price advice... in reply to Beark34, 10-13-2019 07:47:54
Bern's talking about the pivot pin design on the general purpose front end. Pivot pin wear is accelerated with a loader and more so if the operator is abusive with heavy work. Light duty set up, and with these, need to just monitor for wear and make the repair to them timely. They will go a long way before things a sloppy and worse, trust me, you ought to see the front end under my old 850, same design. I always thought based on our 3600 with the same front axle, which had a loader most of its life, that the pivot pin was either slightly different or larger. Our 3600 did a lot of work over the years and towards the end the pivot pin was still within tolerance, not a heck of a lot of wear. Heavy work will test out the spindles, there are some types that are thicker for loader applications, at least in hundred series there is.
Preferably, a heavier industrial front axle is best suited for loader work, but a tractor such as yours would not bother me the least as long as that front axle pivot pin was within tolerance and the spindles did not have stress cracks.
Bern
10-13-2019 15:56:02
 Re: I'm selling my Ford 4000 SU and need price advice... in reply to Billy NY, 10-13-2019 14:17:01
Pivot pin wear is not the only concern. Bent radius rods, bent steering cylinders, loose ball joints, the list goes on.
Billy NY
10-13-2019 18:38:25
 Re: I'm selling my Ford 4000 SU and need price advice... in reply to Bern, 10-13-2019 15:56:02
Yes, seems to take some doing eventually with lots of hard hours, but the whole thing by that point needs an overhaul.
Bern
10-13-2019 10:32:03
Your front axle is a very light duty design that was never really designed from the start with front end loaders in mind. As I said in my prior post, you'll be fine carrying light materials, but heavy stuff will bring trouble down the road. If I were in the market for a loader tractor, I'd skip right past your ad unless you were pretty much giving it away.
Johnofnewhaven
10-13-2019 08:51:07
It has a 3000 front end. I to would not want a loader on it. But would like a 4000SU. They are good tractors.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
