Hi. I have a Ford 2000 1966, 3 cylinder diesel with 7 speed transmission that was made for German market.
As I understand 7 and 8 speed transmissions are the same but on this 7 speed transmission the 4th high speed is blocked by a shaft that connects the high/low shift shaft and the 4th speed shaft so you cant engage 4th speed while transmission is in high range.
Does anyone know how do I unblock the 4th gear when in high range (how do I pull the shaft that blocks it out)?
Thanks!
Thanks!
