Company Logo Shop Now
TractorLinks.com
Re: Have Spark, Compression, Fuel?
da.bees
10-12-2019 22:23:05
The way you explained it you timed it tdc on exhust stroke. If you want to use a pressure-vacuum guage to find tdc of compression stroke,turn by hand until #1 cyl begin's building pressure,remove guage from hole to alow pressure to escape then continue turning until you can see/feel piston at tdc. Flywheel timing mark should be at tdc and rotory button should point to #1 plug wire. It will start from there but you should use a timing light for final setting.
Copyright © 1997-2020 Yesterday's Tractor Co.
