Ford 2000 hydraulic pump
Goalvanny
New User
Ford 2000 3 cylinder gas. 3pt won't raise also no hydro remotes. Removed bleed plug from hydro pump and get nothing. Took side cover off and drained enough fluid to see suction screen. Appears clean. Lending towards needing a pump. Just curious if I'm missing something thanks
(quoted from post at 13:48:16 10/11/19) Ford 2000 3 cylinder gas. 3pt won't raise also no hydro remotes. Removed bleed plug from hydro pump and get nothing. Took side cover off and drained enough fluid to see suction screen. Appears clean. Lending towards needing a pump. Just curious if I'm missing something thanks
So it just up and quit one day? No whinning from pump?
No selector under the seat for the hydraulics?
Guy claims it just quit. If I pressurize
the system with air while tractor running
it'll lift bUT no air pressure no lift.
Will hold 3pt no problem. Tried.Tried to
bleed pump to no luck... I'm assuming an
air leak in suction line maybe. Or would
a weak pump no pull enough vacuum
