Company Logo Shop Now
TractorLinks.com
1710
Gnw43
10-12-2019 10:07:57
Has anyone installed the hose conversion kit for a 1710 four wheel drive on the primary diverter valve right under the hydraulic pump and has anyone had trouble with the hard pressure line not lining back up or fitting right?
ericoberg1
10-14-2019 13:47:00
 Re: 1710 in reply to Gnw43, 10-12-2019 10:07:57
The retrofit was not available at my local New Holland dealer. I figure it took 30 years for mine to start leaking with out the hose retrofit. Got all new o-rings, cleaned the whole mess up, and carefully aligned the valve and mounting. No leaks now for 6 months. The old o-rings all had a flat worn on either the ID or OD.
Gnw43
10-12-2019 20:17:53
I actually had to slot the holes and drill more holes in order for it to all line back up right I m not very pleased about paying $380 with tax for something then have to do all the mods but thanks for all the help
Gnw43
10-12-2019 20:15:13
yes that s it I got it figured out thanks
Scott PA
10-12-2019 16:46:59
Try slotting the holes in the valve mounting plate first to slide the oring in more. Make sure the frame rail bolts are tight.
flembo
10-12-2019 12:57:56
I know this doesn't answer your question but is this the hose conversion you speak of?
Copyright © 1997-2020 Yesterday's Tractor Co.
