Company Logo Shop Now
TractorLinks.com
Order Ford 2000 Parts Online
Ford 2000 hydraulic pump
Goalvanny
10-11-2019 13:48:16
Ford 2000 3 cylinder gas. 3pt won't raise also no hydro remotes. Removed bleed plug from hydro pump and get nothing. Took side cover off and drained enough fluid to see suction screen. Appears clean. Lending towards needing a pump. Just curious if I'm missing something thanks
Jeepjeepster
10-12-2019 10:25:52
 Re: Ford 2000 hydraulic pump in reply to Goalvanny, 10-11-2019 13:48:16
So it just up and quit one day? No whinning from pump?
No selector under the seat for the hydraulics?
Goalvanny
10-15-2019 10:49:40
 Re: Ford 2000 hydraulic pump in reply to Jeepjeepster, 10-12-2019 10:25:52
Guy claims it just quit. If I pressurize the system with air while tractor running it'll lift bUT no air pressure no lift. Will hold 3pt no problem. Tried.Tried to bleed pump to no luck... I'm assuming an air leak in suction line maybe. Or would a weak pump no pull enough vacuum
Copyright © 1997-2020 Yesterday's Tractor Co.
