Company Logo Shop Now
TractorLinks.com
Order Ford 801 Parts Online
Re: 801 won't start when hot...
Sean in PA
10-11-2019 04:23:06
That sounds like the carb is adjusted too lean An updraft system like that should need the choke to start cold, even in warm weather. Running too lean could be contributing to the overheating problem as well. Have you checked for a good spark when it's hot and won't start? If it doesn't have a good strong blue/white spark that will jump at least a 1/4" gap to ground then it's most likely the coil starting to go bad, as they exhibit problems when hot at first and then gradually at lower and lower temperatures until they won't provide a good spark even when cold.
Copyright © 1997-2020 Yesterday's Tractor Co.
