Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
4000 Ford 3 cyl lift cover.
leadfoot04
10-10-2019 21:20:32
Hello all! In the process of rebuilding the lift cover assembly on my 65'up 4000 FORD with independent PTO, I found my check valve stuck. While I had vice grips to pull it out, when it finally come loose the check ball flew the coup. After hours of searching I have give up on ever finding it. My local ford dealer says there is no check ball in it and they cannot locate it in their parts manuals. My "IT" manual plainly shows it in there. Can someone who has the same measure the check ball with a pair of calipers. enclosed is a pic. item number 28
[/img]
leadfoot04
10-11-2019 10:53:38
 Re: 4000 Ford 3 cyl lift cover. in reply to leadfoot04, 10-10-2019 21:20:32
I really appreciate your help! I will check and see if I can find one that size. I save alot of the balls from ball bearings.
leadfoot04
10-11-2019 10:51:34
Thanks.
leadfoot04
10-11-2019 10:49:08
The profit margin is probably not enough. lol
Destroked 450
10-11-2019 08:04:51
Interesting that there's no photo but if one looks at the parts list it's there.
#42 is the guide and #43 is the spring, but between them is #42A - ball 15/32" item # 351666S
Same as for the 4600
Parts guy didn't look hard enough!
Bern
10-11-2019 05:56:04
I'm going to guess that it's a 15/32" ball, based on the fact that it's what a 4600 uses. See number 74 at the link below.
Sean in PA
10-11-2019 04:17:55
I've never had mine apart so I can't tell you for sure, but the parts diagram does not show a ball there at all. It shows the seat (#30 in your picture), the o-ring (#29) and then the guide (#27), but not that ball. They are numbered differently in the parts drawing, but everything else looks the same.
Bern
10-11-2019 05:51:19
 Re: 4000 Ford 3 cyl lift cover. in reply to Sean in PA, 10-11-2019 04:17:55
Must be why the dealer is telling the OP that it doesn't exist. I'd assume that to be a parts manual error.
Copyright © 1997-2020 Yesterday's Tractor Co.
