Company Logo Shop Now
TractorLinks.com
Order Ford 801 Parts Online
Re: 801 won't start when hot...
pinball
10-10-2019 17:17:40
Normally on those fords when you start your tractor the temp will increase to around 180 then you should see it drop quickly which indicates your thermostat is working properly. if it were mine I would completely flush out your radiator and block. if your tractor runs over 190 then you have a restriction or thermostat problem assuming you have a temp gauge to tell you the temp. power washing your radiator will help. to do it right will require removing the radiator to flush out the block as you can stick a hose into the top outlet and let it flush back to the bottom. you can drain your radiator and flush it will water and vinegar, mean green or what ever you have. just remember when your finished to add antifreeze and test for temp freeze. I just flushed out my 961 --4 times--but never could get it to stay below 225 so I bought a new radiator on ebay. now it doesn't go above 170 with a new thermostat and radiator cap. I do believe the previous owner had used a lot of stop leak in it. when a motor gets hot you may be losing some compression due to maybe valves not seating properly. you just need to solve your temp problem first.
Copyright © 1997-2020 Yesterday's Tractor Co.
