Ford Tractors Discussion Forum |
Re: 64 Ford 4000 overheated and blew rad cap off
Author |
[Modern View] |
lastcowboy32
10-10-2019 10:47:30
Maybe undo the fan belt.
See if the water pump bearings failed and the fan now has some slop in it. Maybe that's why it's pulled down into the frame.
That would be best case scenario, from what it looks like. The bearings fail, the fan shaft gets loose, the fan hits the frame and now the belt slips, no fan, no water pump, engine overheats.
If the water pump bearings and fan are still straight and tight, then look at the axle pin. That could easily be worn, especially if you're using a bucket heavily. A worn or broken axle pin could change the position of the engine block and fan, relative to the frame.
What I don't know is how any of that changes when you have that front mount hydraulic pump.
I'm not sure if that pump's shaft goes through where the axle pin used to go... or if you will have a pump shaft and an axle pin. That's where the old time ford mechanics here in the forum and your manual should be able to help you out.
What I do know is that I've read more than a few posts here about how hard that axle pin, king pin, whatever you want to call it, can be to get out. I also remember that the failure mechanisim for when that goes is just like you describe. Instant damage to the fan/radiator/cooling system.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ] |
Home
| Forums
Copyright © 1997-2019 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
