HighlandCow
New User
I have an Ford 881 tractor and it works very well. The transmission doesn't work in reverse 1 and a few other gears.
I decided to attempt to adjust the bands the other day and got a little worried. I disengaged the drive as instructed in the manual and then went about adjusting band 1. It took a while to get the adjusting screw and the locking nut to separate as it was painted over. Once free I started to tighten the adjusting screw and it seemed to not tighten as it just kept going in further and further with no resistance. I decided that this may not be a good idea so i backed the screw out to where I thought it was and tightened it back up.
I had some difficulties putting the drive engagement back in but eventually got it. The transmission seems to run the way it has always has so at least I have a functional tractor.
What am I doing wrong with band 1? Should the adjusting screw go in a long way? Maybe it isn't worth adjusting. Any thoughts?
