Southernborn27
New User
Question -1 what would cause one cylinder to be dry ? (The one the arrow is pointing to) none of the cylinders have pitting it scratches . All pistons are tight and are not loose .
Question -2 what is this ? It can be depressed but not sure what it s for . I m new to tractors and it s probably a dumb question .
Question -3 can all the wiring be replaced and if so how do I find which wiring harness do I need when I don t jnow the exact year of the tractor due to no numbers from pitting and corrosion? Thank you in advance
