Company Logo Shop Now
TractorLinks.com
Re: I can' get this thing apart
Bern
10-08-2019 10:28:59
I'd suggest not doing that, since the end of the axle shaft is a machined thrust surface. The two ends of the axle shaft butt against each other in operation.
Dieseltech
10-08-2019 13:56:48
 Re: I can' get this thing apart in reply to Bern, 10-08-2019 10:28:59
The bar I use is softer than the shaft, so no damage is done. Another way would be to use the left axle in place without the shims and strike the end. May only move .050 inch, but it would knock it loose. I've done that on some Ferguson models.
tripper225
10-09-2019 17:25:58
 Re: I can' get this thing apart in reply to Dieseltech, 10-08-2019 13:56:48
Thank you all.
Great ideas, I'll use them all if I need to.
For now I cleaned up the brakes and put it back together. It's a slow leak so no great loss. I'll keep the new brake shoes for the seal changeover. I've got mowing to do. I'll update when I get it apart.
I will continue to check back for any other ideas so, please contribute if you have a technique not yet mentioned.
Jim
Copyright © 1997-2020 Yesterday's Tractor Co.
