Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
Re: 3 cyl vs 4 cyl 4000
Lynn Patrick
10-08-2019 10:05:57
I can't answer all your questions or speak for everyone, but my "big" tractor is a 3000 gasser.
As to "A", I have found the 3 cyl's to be almost bullet-proof, but so were the 100's.
B. It has good power, the power steering is better than any 100 series I have had (if I'm not mistaken, even Ford called it Power Assist, not power steering), but I prefer the sound a 4 cyl makes when I'm working it!
C. Strictly a personal choice! 3 cyl usually bring more here, too.
Ultradog MN
10-08-2019 15:22:46
 Re: 3 cyl vs 4 cyl 4000 in reply to Lynn Patrick, 10-08-2019 10:05:57
Lynn,
The power assist steering on a 4 cyl and 3 cyl with wishbone front end are identical in the way they work. In fact, if you bent the hydraulic lines from the pump to the column a wee bit you could use the hydraulic block from a 4 cyl in a 3 cyl and vice versa. They use the same seals, same plungers and springs in the hyd block, same upper thrust bearings and same steering cylinders and lines.
I think the pump on a 3 cyl is better as it's gear driven instead of belt driven but I would say the power assist provided by one model is as good as the other.
None of the wishbone PS systems are as good as the integral steering like you'd find in a late 3 cyl 4000 or 4600 as you can out run the hydraulics at low rpms on a wishbone type.
My pal Kenny's 4600 steers like a dream even at low rpms.
Copyright © 1997-2020 Yesterday's Tractor Co.
