Company Logo Shop Now
TractorLinks.com
Order Ford 4000 Parts Online
Re: 64 Ford 4000 - three point hitch stopped working
Andy Wickiser
10-08-2019 08:37:02
Well you're starting the right way - FO-20 has 6 paragraphs for the symptom "WILL NOT LIFT". Once you confirm that your pump is primed, pumping, and developing pressure, you'll have to tackle the lift cover. When you described that the lift position doesn't match the lift lever position that's a sign that your cam follower pin is probably worn thus throwing off the adjustments. Plenty of info in the archives about dealing with a worn cam follower pin. I think you'll probably end up having to refresh then adjust the lift cover to get things working right.
Copyright © 1997-2020 Yesterday's Tractor Co.
