KCTractors
- Location
- Central Wi
Working on a Ford 3000 gas. Will start and shut off when you let up on the key switch. I know the problem is that the wire from the coil back to the starter solenoid kills it when the switch is released. I know that there is supposed to be a resistor wire that goes to the coil. I and another guy looked for that wire and we can not find the wire. I can run a wire from the coil back to the "run" side of the key switch to get power to the coil? Where would the resistor wire originate from the switch end? I do not need the resister wire because I am using a true 12 volt coil with no resistor needed.
