Company Logo Shop Now
TractorLinks.com
Order Ford 600 Parts Online
Ford 3600 PTO
retcol
10-08-2019 04:04:38
Why do I need to idle my tractor way down when engaging the PTO with out grinding. What is the problem and what is the fix?
showcrop
10-09-2019 04:11:12
 Re: Ford 3600 PTO in reply to retcol, 10-08-2019 04:04:38
I suggest your equipment might last longer if you not dump the clutch at high RPMs on a loaded PTO. I like to get my PTO load turning, then raise the RPMs to operation speed. My 3600 does not grind at all. Do you feel vibration from the bearing?[/quote:b8b0918d46]
Faust It appears that you may want to re-read the OP. Retcol, you should alway idle down before trying to engage the PTO, and as Bern said check the pedal free-play and for slack in the linkage.
Faust
10-08-2019 19:31:05
Bern
10-08-2019 05:34:44
Could be as simple as a clutch pedal adjustment, could be as major as a clutch replacement to replace a warped PTO disc.
Start by looking in the owner's manual regarding clutch adjustment. Lacking that, try removing a little bit of the free play in the pedal and see if that helps.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
