Ford 1300 oil leaks
MBoymer
New User
Now that I have received the plug for the clutch adjustment window, I finally got to take her out for a ride. I have noticed a couple of hydraulic oil leaks. The first is by the PTO ( believe that will be a seal replacement.) The second is where the Clutch parts housing meets the transmission housing. There is a leak coming from the lower side of where the housings meet. Is there a gasket that I am missing? Couldn't seem to locate one in the parts catalog. Thanks in advance.
be real sure what the fluid is, if engine oil, probably rear main crank seak is leaking, if you're sure it's hydraulic oil, then either the transmission input seal (item #35)or the sealer used on the input seal case has most likely failed
input seal parts picture
