KCTractors
- Location
- Central Wi
I need to install a 3-wire Delco alternator on a Ford 3000 gas for a Friend. I never did a 3 cyl or
newer tractor. I have installed many on the older Ford tractors with good results.
I need a good wiring diagram or directions as how to do it. I know that the heavy wire from the
generator goes to the large post on the alternator and #2 terminal goes back to that same wire and then
that wire would go to the battery terminal that was on the regulator. Now the #1 terminal in the
alternator would go back to the WL terminal on the regulator.
I can take all the terminals off the regulator now. Is this the correct way to do this?
