Company Logo Shop Now
Order Ford 600 Parts Online
600 hood mount
JDBDAVE
10-04-2019 15:36:19
I am about to install a new set of sheet metal on a 620 ln a 620 Sherman forklift tractor. There are two sets of holes in the front axel support to attach the hood. Which set, upper or lower should I use to mount the hood? Thanks.
michford
10-05-2019 06:34:44
 Re: 600 hood mount in reply to JDBDAVE, 10-04-2019 15:36:19
Are you using the original dash panel from your 620? If yes, then like Wayne said, use the lower holes. If you are also relpacing the dash panel, check the location of the hole for the steering shaft. A 600/601 dash panel steering shaft hole is further away from the edge of the panel. An 800/801 dash panel steering shaft hole is close to the edge of the panel. This difference is due to the steering shaft being on an angle, so when the hood sheetmetal is mounted higher, the hole in the dash panel has to get closer to the edge. The hood sheetmetal is physically the same, the dash panel determines which height the hood sheetmetal has to be mounted at.
WayneIA
10-04-2019 18:07:03
If the fuel tank, dash and steering gear are original, then the bottom holes should be used on the 600 series. The top holes are used on the 800 series ,with the larger tank dash etc.
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
Latest Ad: McCormick Deering 22-36 Tractor has been restored by previous owner. Runs great looks great. Tractor has automotive paint that is really sharp. Tractor shows really well. Would make a nice addition to a IH collection. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
