Company Logo Shop Now
TractorLinks.com
ford 340b PTO
cdv
10-04-2019 14:14:40
got a nice 340B today but pto wont shut off handle on or off stays running thanks cdv
Ultradog MN
10-06-2019 07:17:46
 Re: ford 340b PTO in reply to cdv, 10-04-2019 14:14:40
With the PTO Off use a 2x4 and pry against the pto shaft to stop it. If it stops easily it is your pto brake. If you can't easily stop it from turning it could be as Shuan says, your pto clutch has problems or, it could be the control valve is sticking.
If it is the clutch pack it requires a rear split and lift cover removal. If it's the control valve it can be fixed by pulling the lift cover.
That brake is kind of weak and cheesy. There are many guys here with that brake worn out. As long as it shuts off with an implement hooked to the pto they just live with it and shut the engine off to hook/unhook the pto.
Shaun Wallace
10-04-2019 14:40:44
Its either pto brake worn out,its a 3/4 inch square bronze pad or discs welded together. Both require split at trans/rear axle.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
