Company Logo Shop Now
TractorLinks.com
Order Ford 841 Parts Online
Re: 841 value
Dean
10-03-2019 05:23:51
Insufficient information but would guess $4,000 - $4,500 from available information. The market is not good but will likely worsen rather than recover.
Be interested to know where the "new spin out rims" came from.
Dean
jimf in mo
10-03-2019 19:53:53
 Re: 841 value in reply to Dean, 10-03-2019 05:23:51
Dean basically remand the old ones Made a spacing jig for the adjusters. there are spaced equally. numbered each one in relation to the valve stem hole on the rim made a little jig to reference spacing from valve stem hole to 1st adjuster. cut spot welds out of old rims with spot weld cutter. bead blasted parts . got new 28" blanks welded in adjusters at same spot aa old welds. bead blast again. rims were then dipped in a etching primer at a local shop before painting. I called that new guess remanufactured would be the proper term
Dean
10-04-2019 05:33:23
 Re: 841 value in reply to jimf in mo, 10-03-2019 19:53:53
Thanks, Jim.
Sounds like a job well done and lots of work.
Dean
Copyright © 1997-2020 Yesterday's Tractor Co.
