7600 wiring harness
dbeam
In my effort to remove the pit man arm I caught a puddle of power steering fluid on fire burning up the wires around the key switch. Anyone no where to get a good replacement harness, also need one that goes over fuel tank as its wires had been rubbed through with age. Thanks.
The harness that goes over the fuel tank is the same one that feeds the key switch. This is known as the rear main harness. The one over the engine is the front main.
Thanks Bern. At the fuel tank the harness has a plug that connects two different segments together, if I get a rear harness will it have both segments or be made with out this plug? I'm asking because before I burnt the other wires to the other plug all ready had missing insulation so I need both.
Either a front or rear main harness will each have two plugs that mate together at the front of the fuel
tank. The rear harness will also have a 3rd plug nearby that plugs into the voltage regulator.
Agri-Services, Wiring Harness Specialists, 716-937-6618, www.wiringharnesses.com. OEM quality and lower price. Given the OEM price from New Holland is very high,
but this is a 50 year old tractor. I got a complete harness for 4000SU. Fit and quality excellent. Product support excellent.
