Today I installed the thermostart setup on my 3000. While had it apart I replaced all of the return lines on the top of each injector which return fuel to the tank. I did put a brass T in the line which feeds the thermostart. After all that I tried to start the tractor and had a real hard time staring. got a lot of white smoke, I mean a lot of white smoke. The tractor finally started but it didn't want to. After running for quite a while I checked inside the fuel cap and din't see any fuel dribbling out of the return line. So with no return fuel I doubt the thermostart will be getting any fuel to work properly.
If you all remember i just replaced broken rings on two of the pistons with all new rings and honed the cylinders. Do i need to be patient and break in the engine more? or do i have a injector or injection pump problem?
Why is this tractor starting so hard cold? The weather was mid 60's today so not cold at all.
Thanks for any help i can get
