Company Logo Shop Now
TractorLinks.com
Order Ford NAA Parts Online
Re: Jubilee ignition troubles
mkuhns
10-02-2019 16:55:55
Used napa and tisco points and condenser. Tried a jumper to coil and battery charger to increase voltage at coil to no avail. Who else make good points and condensors anymore that you can trust. So if I go with electronic ignition do I just need to install the pickup in the distributor and plug wires I believe? I can leave the 6 volt system intact?
Alan8n
10-02-2019 20:34:55
 Re: Jubilee ignition troubles in reply to mkuhns, 10-02-2019 16:55:55
Yes you can leave the 6 volt system alone, I did. You add the pickup in the distributor and I also added a Flamethrower coil as well. If your plugs and wires are old you may want to change them as well but I don't think it's absolutely necessary.
I must stress that a good 6 volt battery is very important as the Pertronix requires a specific minimum voltage to work.
Again I made all of these changes 1 time and never messed with it again.
It is the single best improvement I made to both of my tractors. They both start with the first push of the starter button.
HTH
Alan
Copyright © 1997-2020 Yesterday's Tractor Co.
