Ford 2110 clutch alignment tool
mtestagolf
New User
I have a ford 2110(mid 80's), 4 cylinder diesel. It has the 2 disc clutch and has the shibura engine in it. I finally found the right clutch for it, but cant find the right alignment tool. It has the 9.5 dual disc, one disc is 15/16 with 13 spline, and other disc is 1 3/8 19 spline. The pilot bearing inside is .4724-.475. I can find clutch alignment tools for the right spline count and size, but cant find the right pilot size, the smallest pilot size is .669. Any help would be great, thanks Mark
I have done various clutches including combined clutches and a double disc with a floater without an alignment tool. I put it on with it close and tighten the bolts to not quite snug, then just stick a broom handle or piece of tubing in to get it close, just edging the discs with a screwdriver. Then tighten to spec. When slipping the back end back to the front turn the PTO shaft to get it to mesh.
