Company Logo Shop Now
TractorLinks.com
Order Ford 3000 Parts Online
Ford 3000 live pto
Adam1992
10-01-2019 21:36:51
Bought a ford 3000 diesel 8 speed transmission that does not have live pto. Was wondering can I put live pto in it or is the transmission different
Sean in PA
10-03-2019 05:28:11
 Re: Ford 3000 live pto in reply to Adam1992, 10-01-2019 21:36:51
nashranch, it looks like there's another 4 off to the left of that 46 or 4C. Try a pencil rubbing on a piece of paper to see if you can bring up hose missing numbers.
46 makes no sense as part of a 1965 3000 model number, and nether does 4C, but 4C does make sense at the end of a 4000 series model number as the 4 would mean independent 540 rpm PTO and the C would mean an 8 speed transmission. A 3000 with an 8 speed was only available with live or non-live PTO, never Independent PTO. So maybe the transmission was swapped out at some point?
Sean in PA
10-03-2019 05:14:12
As Ultradog has said, from that model number that's a transmission driven (non-live) PTO.
nashranch
10-02-2019 17:37:48
Made in U.S.A. for sure, can't tell you about the Live PTO though
Adam1992
10-02-2019 17:23:51
Quoting Removed, click Modern View to see[img][/img]
There s the numbers on mine.
Ultradog MN
10-02-2019 18:08:17
 Re: Ford 3000 live pto in reply to Adam1992, 10-02-2019 17:23:51
31022c
3= 3000
10= ag/all purpose
2= gas
2= transmission 540 pto
C= 8 speed
nashranch
10-02-2019 14:11:06
They did a C r a p p y job of stamping on this one. All I can read is 46 or 4C on the middle row
Destroked 450
10-02-2019 09:36:04
nashranch, yours was build Dec 16, 1965 in Basildon, England
Unfortunately the middle row is the model ID numbers that tell what it has.
Adam1992
10-02-2019 09:22:41
I ll get the numbers off it when I get home tonight.
nashranch
10-02-2019 09:11:45
I am wondering also if my 3000 has live PTO or not, Here are my numbers. Can't read the middle set of numbers
Shaun Wallace
10-02-2019 08:41:36
It may have live pto but clutch may not be adjusted correctly. Have seen this a few times over the years. Of course posting numbers off foil sticker or off machined surface to rear of starter will tell the real story.
Destroked 450
10-02-2019 08:35:02
I have a spare live pto 8 spd for a 3000 but used the clutch and flywheel.
Sean in PA
10-02-2019 07:56:31
Make sure that you get an Over Running Clutch on the PTO if it doesn't already have one. That will keep a heavy implement from continuing to push the tractor forward when you push in the clutch and put on the brakes.
Sean in PA
10-02-2019 03:42:16
It would take a lot of parts and labor. The non-live PTO tractor has a single clutch and the PTO shaft is driven off of a counter shaft driven by the transmission itself. The live PTO needs a double clutch and a different input shaft assembly on the transmission that transfers the power from the two different clutch discs to two different shafts inside the transmission, and then the PTO itself is driven off of the second clutch disc.
It would be cheaper and easier to find an 8 speed with live PTO from a tractor with a blown engine and swap the whole trans, including the flywheel and clutch to your tractor, or find a good tractor that has live PTO and buy that one and sell yours.
adam1992
10-02-2019 06:34:35
 Re: Ford 3000 live pto in reply to Sean in PA, 10-02-2019 03:42:16
Sean thanks for the info. I think Iíll prolly just leave it alone donít sound like it would be worth the time and money
Copyright © 1997-2020 Yesterday's Tractor Co.
