Company Logo Shop Now
TractorLinks.com
Re: 961 ford
MarkB_MI
10-01-2019 02:03:21
You might have overfilled it. Did you check the level using the hydraulic reservoir dipstick?
If ATF drains out, gear oil probably will as well. I use 85W-90 gear oil in mine, which is what is recommended.
I want to re-emphasize the importance of draining out any water in the pedestal. Do that before re-filling.
pinball
10-01-2019 05:13:46
 Re: 961 ford in reply to MarkB_MI, 10-01-2019 02:03:21
when I pulled the plug it looked like a dip stick. prpbably 4/5 inches long with a band about an inch from the bottom. is this what your talking about.
MarkB_MI
10-01-2019 14:21:13
 Re: 961 ford in reply to pinball, 10-01-2019 05:13:46
I don't think my plug is like that. If you pull the hydraulic reservoir dipstick, located below the seat on the left side of the tractor, you should see it is marked on both sides, one side for the hydraulics and the other for the pedestal. There are two marks and you line the top mark up with the top of the filler hole and read the oil level against the lower mark. On my dipstick these two marks are 2-7/8" apart.
pinball
10-01-2019 05:11:36
I haven't been able to find the drain on it,
MarkB_MI
10-01-2019 14:23:36
 Re: 961 ford in reply to pinball, 10-01-2019 05:11:36
It is a 1/4" pipe plug in the front of the casting. And it will probably require heat to break it free.
Dean
10-01-2019 05:59:24
Anything bolted to the front bolster?
If so, remove and have another look for the drain plug.
Dean
Copyright © 1997-2020 Yesterday's Tractor Co.
