New lower lift arms Ford 850.
338ftw
Both of mine are shot. Can someone recommend a good set of replacements? I need a set for more than just show.
You can get them off this site:
https://www.yesterdaystractors.com/cgi-bin/store/model_parts.cgi?SearchArea=Ford&&md=850&cat=Hitch%20/%20Drawbar&r=mcats
(quoted from post at 15:50:13 09/25/19) You can get them off this site:
Are they high quality?
(quoted from post at 18:08:47 09/25/19)
338, how many years did your current set last you?
Current set is fine except the balls are wallered out. Would it be better to weld on new ends?
if both ends are shot, it's certainly easier to just buy replacement arms. If you're a welder, you could save ~50% buying replacement ends and spending a couple/three hours cutting/grinding/welding/grinding/ painting.
Farm stores around here have replacement arms in stock for about $60 each, Countyline brand, they look good to me.
One observation, replacement arms come in different thickness, make sure the ones you get are the same as the ones you are replacing to minimize fussing.
You might want to get new pins too....
ebay has them for about 65 bucks a pop. Pay close attention to the verbiage in the ad as they sell different arms for different tractors.
