Company Logo Shop Now
TractorLinks.com
Order Ford NAA Parts Online
Re: Cotter pin, bottom of transmission/differential? NAA, oi
Sean in PA
09-30-2019 04:58:13
The differential is in the center of the rear axle, under your rear end when you're sitting on the tractor.
As others have said, that area with the cotter pin is the bell housing where the clutch resides. That area is supposed to be dry, but can get fluid in it if the front of the transmission or the rear of the engine leak, and the hole with the cotter is there to let any fluids that get in there to have a place to drip ot so the clutch doesn't get contaminated with oil. The cotter pin itself is supposed to be a loose enough that it rattles around from the vibrations of the tractor running to keep the hole from getting clogged up with dirt and mud, so the hole stays open.
Copyright © 1997-2020 Yesterday's Tractor Co.
