Just noticed a significant oil leak in my Ford NAA. There is a cotter pin with the two bent ends sticking out from a hole under either the transmission of differential, not sure which. Oil seems to be seeping out. I have a short owners manual with a diagram and if you look close the cotter pin is shown. In the cut away view it is just forward of a drain plug that is directly below shift lever. First question, in the cut away there is a large area with what appears to be two drain plugs and is directly below steering gear box, cotter pin appears to be just at the far rear end of this area just before a wall which divides to next compartment back that has all the gears. Is this area the differential and next back transmission? What is the purpose of the cotter pin and what can I do about leak and finally what sort of fluid should I use. I have read of something that seems to be useable in hydralics, transmission and differential. Thanks all for any help on my NAA anatomy questions.
