Company Logo Shop Now
TractorLinks.com
It's alive! Now what?
Thelumberwagon
09-29-2019 13:10:38
For many of you, you've seen some of my random topics about my newly acquired 3000. As you've probably noticed, I'm new to the tractor scene and have been digging for advice.
Well I put a fresh battery in the old girl as well as some fresh gas and the sumbitch fired right up and runs great. No smoke, knocks, valvetrain clatter or anything. I'll change all the fluids and filters but should I just leave it as is and haul it to the farm and start mowing? I still have to address the front tires though. And a new seat...damn those are spendy! Also needs brakes but I'm not intimidated by that.
I was convinced that I'd have to put a new zenith on it and even contemplated electronic ignition. I'm not so sure of that now. The mower even works and I've greased all the zirks and so it's good to go. The power steering was dry but it came to life with some new fluid.
The only issue I have is that it almost got stuck in soft gravel due to not having the diff locked. I don't even know if I can lock the diff but in the whole scheme of things, I can live without a locking diff (any insight on that would be welcome).
So is she good to go or should I still swap the carb and contemplate the ignition upgrade?
Thanks guys, I really appreciate all the support and advice.
Thelumberwagon
09-30-2019 18:55:14
 Re: It's alive! Now what? in reply to Thelumberwagon, 09-29-2019 13:10:38
[quote="Thelumberwagon"](reply to post at 18:51:30 09/30/19) [/quote
I'm only a 1000 bucks into it and it came with a Ford bush hog so I'm far from complaining about it. I'm just trying to set my expectations realistically with it.
Ultradog MN
10-01-2019 03:27:56
 Re: It's alive! Now what? in reply to Thelumberwagon, 09-30-2019 18:55:14
"I'm just trying to set my expectations realistically with it."
I've learned to not have real high expectations on the brakes on these tractors. Ford used the same type of outboard, dry drum brakes from 1939 till well into the 1980s. They are adequate but just. The 4000s in that series had internal, wet disc brakes that were much (vastly?) superior.
Thelumberwagon
09-30-2019 18:51:30
I was backing up in loose gravel and trying to back over a 6x6 block of wood. I figured I'd go right over it but alas...it just spun. So i had to dismount and move the block. Brakes arent stomg enough to stop the wheel and engage the other other wheel.
Sean in PA
09-30-2019 18:00:39
So what were you attempting to do that it was spinning a tire with 5 weight rings on each rear wheel? I have a '73 4000 with the S-O-S transmission and no diffy lock and no weights, and I have started out from a dead stop in 5th gear in a muddy field many times and never spun a tire. 5th gear will pop the front wheels off the ground when starting with the brush hog raised in the back unless I have it at or near idle.
Thelumberwagon
09-30-2019 15:51:31
Previous owner said the tires were filled but I'm not so sure of that. It does have 5 weight rings on each rear though so it's plenty heavy.
makoman
09-30-2019 04:33:56
Are the tires loaded? When I added pie weighs to my 2000, tires hardy spun with spring tooth plow. Before that had lots of spins.
Thelumberwagon
09-29-2019 17:27:11
Nah, no sign of any of those parts. I don't have the means to swap out the back half of the tractor and salvage tractor pats seem to be scarce in the KC area even if I did have the means.
I will do the "seat of the pants" diff lock. I have to remove the brake rod on the left side to straighten it. Previous owner clearly ran into something that got between the wheel and tractor and bent it pretty good. The brake on that side is worn out as a result. Only way to straighten it is to remove it and apply some heat or use a press. I will replace the shoes at the same time.
sotxbill
09-29-2019 15:05:19
Need to use the "seat of the pants" diffy lock...you simply apply the brake to the side that is spinning.... and the other side will mysteriously start pulling.... Its been done for years before the diffylock was available.
But that would mean that you need reasonable brakes... so you might pull the hubs and super clean all the fluid and grease off the shoes... and then adjust them to get a good pedal...
Thelumberwagon
09-29-2019 14:56:31
Nope, I don't have one of those.
Seems odd that they would make a tractor without one a locking diff.
I'm learning real fast a fella would upgrade to a tractor with more options. It'll still do what I need it to do though, which is mow.
Ultradog MN
09-29-2019 15:39:43
 Re: It's alive! Now what? in reply to Thelumberwagon, 09-29-2019 14:56:31
Yes.
Diff lock was optional on most 3000/4000 models - at least in the early years. It may have become standard later.
It was not even available on the early 2000s. Sometime later the trumpet on the 2000s were changed from the early round cross section to the square cross section like the 3000s used and diff lock became available as an option.
Does your tractor have the little lever #18 in the diagram on it?
The first 3000 I owned did not have parts numbered from 1-16 in the diagram posted by Bern. Interestingly enough, it Did have parts numbered 18-23 and the internal parts.
An odd delete halfway through the building of the tractor.
It was during a search for those deleted parts that I found a complete 8 speed lpto transmission and rear end - with diff lock and ended up replacing the whole back half of the tractor.
Bern
09-29-2019 14:59:27
I guess Ford assumed that anyone who bought a 2 or 3000 back in the day wanted a base model that was as cheap as possible. Diff locks are nice to have, but not mandatory for everyone. Even the "high end" 6000 tractors, built during the same time period, did not have a diff lock.
Bern
09-29-2019 14:36:08
I believe that diff lock was optional on the 3000. Regardless, here is a pic of the linkage. The pedal resides near your right heel.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
