Company Logo Shop Now
TractorLinks.com
Re: Reverser Trans Question
indford
09-27-2019 14:39:24
is it the Sherman that is jumping out or the 4 speed trans? What is the series and model of your tractor? Is it a late 1950's early 1960's 4 cylinder 4 speed Tractor? Maybe a 1801/1821 or 1801/1841?
indford
09-27-2019 19:04:31
 Re: Reverser Trans Question in reply to indford, 09-27-2019 14:39:24
I wish I could says it was all the shifter's fault, but it is more than likely the reverser will need a rebuild.
duckrock
09-27-2019 15:18:48
It is a late 50s early 60s, 4spd, 1841. It is the reverser that either pops out of gear or won't go back into gear (sometimes) when I'm trying to shift the reverser. With the slop in linkage it is possible the gear lever isn't moving the internal parts far enough forward and backwards. I'll try to get some pictures tonight.
duckrock
09-27-2019 16:36:34
 Re: Reverser Trans Question in reply to duckrock, 09-27-2019 15:18:48
Top two pics are with the shifter handle in forward and aft positions. Moving the handle causes the shaft thru the trans to move slightly in/out and front/back. Seems like there should be a grommet in the trans case to keep the shaft centered and eliminate the moving. Last pic is the handle. It can move left/right which makes the shaft going thru trans case move. What I can't show in still pictures is the slop in the pin/oval connection.
Bern
09-27-2019 16:42:56
 Re: Reverser Trans Question in reply to duckrock, 09-27-2019 16:36:34
As I said in my last post, if the shift handle is not hitting anything in its travel, your problems are internal in the box.
Copyright © 1997-2020 Yesterday's Tractor Co.
