Company Logo Shop Now
TractorLinks.com
Order Ford 4500 Parts Online
4500 steering box problem
Tom RS
09-27-2019 13:10:03
A friend has a 1968 4500 that he has a problem with.
When.he turns the steering wheel one way the steering wheel rises until it hits a point where it will steer. Then turning the other way the steering wheel lowers back down to where it should be and then will steer in that direction. So to me it seems the worm gear is riding up and not staying put. Maybe a split ring or collar is loose?
Does anyone have a exploded view diagram of this box? It sits on top of the tranny under the instrument panel. Thanks in advance for any info.
Bern
09-27-2019 14:26:20
 Re: 4500 steering box problem in reply to Tom RS, 09-27-2019 13:10:03
The upper bearing #12 is toast.
Tom RS
09-28-2019 08:06:13
 Re: 4500 steering box problem in reply to Bern, 09-27-2019 14:26:20
Follow up question.
Could the pedestal be taken off and this bearing be replaced without disturbing the lower larger unit?
I suppose one problem might be the pieces of the old bearing and where did they go.
Bern
09-28-2019 09:33:40
 Re: 4500 steering box problem in reply to Tom RS, 09-28-2019 08:06:13
I believe you could, yes. And yes, I'd be concerned about getting all of the loose balls out of the bottom of the unit without a complete disassembly.
Tom RS
09-27-2019 20:08:22
Thanks for the reply - very helpful.
Copyright © 1997-2020 Yesterday's Tractor Co.
