Company Logo Shop Now
TractorLinks.com
need some help
larry@stinescorner
09-27-2019 03:59:34
My waterpump on the FORD 2000 is starting to make noise. My friend Jim said order a new waterpump and we will change it, I looked it up on Y/T parts to order it. I have a 1973 model 2000 with the 3 cyd gas ,,I want to make sure I Order the right one,,and all the gaskets I need. Do I need the motor number?I looked up the part,,but wasnt sure what to order.I did order a starter drive,and it came last week and worked out great so far,,but the waterpump I Could use some reassurance from experts before I send for it.
Thanks in advance!!
Tom in TN
09-28-2019 11:55:32
 Re: need some help in reply to larry@stinescorner, 09-27-2019 03:59:34
Larry,
One last little idea. You would be wise to look closely at the fan belt while you have the machine disassembled. I recently replaced the belt on my 1973 Ford 2000 3 cylinder gas tractor. It wasn't possible to get the belt out between the fan blade and the shroud. I had to remove the hood, front nose cover, front bumper, and radiator to replace the belt. Way too much time and effort for such a simple task.
YMMV, but that's what I had to do on mine.
Tom in TN
Destroked 450
09-27-2019 08:18:02
When you unbolt it the entire pump and back housing comes off together, then you have to separate the pump from the back housing, clean 3 gasket surfaces, both sides of the back housing plus the engine block, install the pump onto the back housing and then reinstall the assembly.
I'd spend the extra $13 to get the pump and back housing already pre assembled , clean the gasket surface on the block and install the new pump assembly.
Sometimes saving a few $ isn't worth all the extra work involved.
Sean in PA
09-27-2019 04:46:30
To be sure that you get a water pump for 3 cylinder 2000 rather than the earlier 4 cylinder 2000, make sure that the listing says that it is also for a 3000, as they both used the same water pump and there was only ever the one 3 cylinder model called the 3000. The 3 cylinder 2000 and 3000 tractors are almost identical except for a few small differences. The 3 cylinder engines used the same water pump for both gasoline and diesel models. It looks like YT sells two of them that claim to be correct for your tractor, one with the back housing already installed, and the other without, so you swap the back housing from your old one to the new one, for about $13.00 less. They both come with the gasket:
Water Pump with back housing and gasket.
Water Pump with gasket but without back housing.
larry@stinescorner
09-28-2019 03:59:39
 Re: need some help in reply to Sean in PA, 09-27-2019 04:46:30
thanks for the replies,,Im going to send for the one with the back housing on it
mikewood869
09-27-2019 04:36:54
Parts break down:
https://partstore.agriculture.newholland.com/us/ScottSupplyCo/parts-search.html#epc::mr64888ar452540bi4212932-1
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
