Company Logo Shop Now
TractorLinks.com
Re: 961 ford
pinball
09-26-2019 19:15:31
I have a volt meter. there are no wires on the alternator. just a black and red post. do I put the black post wire to the ground and the red wire from the red post to the positive side of the battery just to check it. thanks.
MarkB_MI
09-27-2019 02:31:02
 Re: 961 ford in reply to pinball, 09-26-2019 19:15:31
Yes, you can check the voltage from the positive battery terminal to ground. Probably around 12.5 to 13 volts with the engine off, then 14 to 15 volts when it's running. If there is no change in the battery voltage when you start the engine, then the alternator is not charging.
You say there are "no wires on the alternator". If, indeed, it has never been wired up then it's not going to be charging the battery.
Copyright © 1997-2020 Yesterday's Tractor Co.
